Randy_T
- Dec 18, 2001
Under $1700 (Today Only). Includes screen (Widescreen Format).
Turn your home into a serious home theater with the addition of this Panasonic 800 Lumen Home Cinema Projector! From big blockbuster movies to the drama of great sporting events, you'll feel like you're in the middle of it all!
Features:
800 ANSI Lumens brightness
800:1 Contrast ratio
Three 1/4" HD 16:9 wide screen LCD panels - 4:3 compatible
960 x 540 Resolution
Whisper-quiet 28DB
6.4 lbs
SD Memory card slot
Digital cinema reality circuit
3-Dimensional Y/C separation
Up to 5000-hour lamp life
294-Pattern user-adjustable picture equalizing
16:9 Aspect ratio LCD panel
Screen size: 40" to 200"
Video & PC input terminals
Backlit, multi-function wireless remote control
2 Watt speaker
Enhanced noise reduction technology
Digital keystone correction
DVI-D Input
Low-noise cooling fan
Carrying case included
One-year limited warranty
Go
HERE
Features:
Whisper-quiet 28DB
6.4 lbs
SD Memory card slot
2 Watt speaker
DVI-D Input
Go
HERE
