Rob FM
- Jan 15, 2001
- R
I then loaded Windows ME, made 2 partitions on the Hard Drive ( C: & D: ).
Did you actually create both hard drive partitions within Me? The usual course of action with the 9x based versions of Windows is to partition the drive then install the OS.
[Edited last by Rob Gillespie on August 14, 2001 at 02:26 AM]
having never installed Me
Rob,
You are much wiser by never doing this.
-Dean-
Windows takes its pick on what to call them
Not sure that's right there Iain. The letters are usually assigned by priority in the order I listed above. A hard drive will always come before a CD drive in letter. And if you've got two drives one the same channel, the master always gets the first letter.
I think I'd be tempted to remove the two CD drives and get the HD letter assignemnts correct. Then add the two CDs back hopefully it should all fall back into place.
