- Aug 20, 2000
Does the Superbit "Air Force One" use different masters? I could tell there were some differences between the DD and DTS tracks, especially during the refueling scene.
You should hope they use different masters. The Dolby Digital video master is sometimes dumbed down for 2 channel downmixing and other things.
Now Dan, we've been through this before. I don't know what the "other things" are you refer to, but in those rare instances where a soundtrack master has been reconformed to accomodate downmixing ("dumbing down" you called it?), it makes absolutely zero difference on a properly configured audio system.
But I know you know that. You just like to bring it up once in a while for those that don't know that.
There's no reason anymore why we can't have our cake and eat it too (especially doing full bitrate DTS 24/96 or DTS-ES Discrete 6.1
Nothing apart from no one using full bit-rate DTS, no theatrical material that could use 24/96 DTS, the questionable value of a 24/96 lossy format in the first place (not that we can judge as no software actually exists yet) and an extremely limited selection of material that would require DTS ES in any form.
Adam
