How do I turn off hardware accelration (1 Viewer)
Anders Englund
I'm going nuts over this. I'm trying to turn off hardware accelration when playing DVDs on my computer (Compaq 7000 series, Windows ME), so I can make some screenshots. Any suggestions?
--Anders
AllenD
I'm not familiar with Compaqs. What software are you using?
Signature? I don't need no stinkin' signature.
Anders Englund
Windows ME's internal player, PCFriendly, Compaq DVD Player. Hey, I'll use any player you say will do this for me. I don't really watch DVDs on my computer anyway.
--Anders
Camp
Define "hardware acceleration" in this case. Do you have a hardware decoder? Why is "hardware acceleration" the reason you cannot take screen shots?
Peter McDonald
Go to "Start > Settings > Control Panel > Display" (or something like that, that's how it is on Win98, not sure about ME).
Click on the "Settings" tab, then "Advanced", then there should be a tab called "Performance". The control for hardware acceleration is on that page, slide it down to "None". And now you should be able to take screenshots of your DVD's :)
Let me know if you have any problems.
Peter
Anders Englund
Peter, I tried that. It doesn't work. What I'm trying to achive is just using a software decoder, which is not the case right now. The computer has a GeForce 2, and I think that's what being used.
--Anders
Iain Lambert
Anders, I'd suggest you try a different tack, and rather than trying to grab it that way I'd use Hypersnap DX. There is a free trial version, and that usually does a great job of grabbing the frame. If you leave all your hardware accelleration on you usually end up with the shot in its native resolution as well, for extra quality.
Anders Englund
I managed to do it. I had to download a different player which doesn't support hardware acc. Then I could use Hypersnap. Thanks guys!
--Anders
Link Removed
Ob me Deus cavet
vasyear
