How do I get my PC to stop asking for a login?
Discussion in 'Archived Threads 2001-2004' started by Ted Lee, Sep 29, 2001.
  1. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    hi all -
    i have a notebook running win98 at home. it used to be hooked up at work, where a login was needed. since it is now a stand-alone, is there anyway to get it to bypass the login screen?
    tia
    You step in the stream,
    But the water has moved on.
    This page is not here.
  2. Rob Speicher
    Rob Speicher Supporting Actor
    Nov 24, 2000
    935
    Go to network properties, change Primary Network Logon to "Windows Logon" (if it isn't already).
    Then do a file search for *.pwl (all password list files) and delete all of the results. I think this should take care of it, but it's been a while since I've had to do it.
  3. Shayne Lebrun
    Shayne Lebrun Screenwriter
    Jun 17, 1999
    1,086
    Right click on 'network neighbourhood.' Select properties. The 'Primary Network Login' combo box probably has 'client for microsoft networks' selected. Change it to Windows Logon. Reboot. Don't supply a password when it asks on reboot, and it should leave you be. If not, delete all of the .pwl files from your windows directory, reboot, then don't supply a password.
  4. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    thanks guys -
    it worked perfectly! thanks for the help.
    [​IMG]
