DeathStar1
- Dec 28, 2001
- Neil
that I feel thinner, and that I'm loosing weight, but the scale says I'm either the same, or are fluctuating between 220 and 230.
Is it possible just not to loose anymore weight than what I've done already? If you beleive the scale, I've gone from 245 down to 225, and have basically stayed there for the last year or so.
I've heard of stomach stapling, but have a weak stomach for surgery, so I think that's out.
What I'm going to do, is go down the shore for two weeks starting Friday, since I usually tend to eat less down there for some odd reason, and ride my bike for 8 miles a day and see if that helps any.
Anyone else in the same situation I am?
