How can I tell if an LCD display has 1080p native resolution?
Discussion in 'Gaming' started by orestes, Sep 3, 2006.
  1. orestes
    orestes Second Unit
    Jun 12, 1999
    280
    See title question. For instance, does this Samsung http://www.bestbuy.com/site/olspage....=1142298457279
    have 1080p native resolution?
    Here it is what Samsung.com says about the specs for unit mentioned above:
    http://www.samsung.com/Products/TV/L...Specifications
    Hmm, it does not say anthing about being a HD set at samsung.com web site; however, bestbuy.com says it is a HDTV unit. Isn't this confusing?
    Also, from the description at samsung web site, it looks as if this type of unit required a "lamp" as the DLP sets. Isn't this a problem too if you have to change the lamp every two years or so? Isn't the lamp a bit expensive?
    Thanks.
  2. Seth=L
    Seth=L Screenwriter
    Jul 17, 2006
    1,313
    It is a 1080p monitor. It even says in the specs at Samsung.com under HDMI and Component.
  3. Alon Goldberg
    Alon Goldberg Screenwriter
    Jul 10, 2006
    1,131
    The spec sheet (linked on the Samsung site at the top right) shows that this set has a native resolution of 1920 x 1080p. And as Seth noted, the specs also show that the set is capable of 1080p via Component or HDMI. This is indeed a True 1080p HDTV set. [​IMG]
