High-Definition TV is in 16:9 (1.78:1). A widescreen set is the same ratio. So there are no black bars on a HD TV program (sports or whatever).
Now, film-based sources like movies may be in a wider aspect ratio such as 2.35:1, in which case there will be black bars top and bottom when broadcast correctly in HD. Or if an older 4:3 (1.33:1) movie was broadcast in HD it would correctly have side black bars. All this is just like with DVD. Except HBO-HD crops the wider movies to fit the 16:9 screen so there are no black bars. Just about as bad as current pan-n-scan hacking of movies for presentation on 4:3 TVs.
It is true that NATIVE HD is 16:9, and will fill your screen. However, there have been reports on other forums that some stations simply upconvert NTSC material, and that on some TVs this results in a window boxed presentation. It has been awhile since I read this, and I do not recall where, but I do remember reading this.
George,
That's exactly what I read. It seems reasonable enough to me that not all content has to be enhanced for widescreen tvs to still be HD but what do I know??
Upconverted 4/3 shows on my one local ota station and on HBOHD are presented with black bars on the sides only. If a commercial that would be letterboxed on a 4/3 set comes on, it's got bars top and bottom also.
HBO-HD is no longer mutilating all 2:35 movies to eliminate black bars, by the way. I've seen several 2:35 movies on HBO-HD with black bars on my widescreen set.
Steve S.
I prefer not to push the subwoofers until they're properly run in.
