Lee Scoggins
http://www.goldmund.com/old/mininews.html
This is the official Goldmund news story. Looks compelling!
Of the 25 or so Hi-Rez discs I own, I would say that the best sounding discs I own are Big Phatt Band (DVD-A), Beck's Sea Change (SACD), Bowies Heathen (SACD), Swing Live (DVD-A, which I do not care for musically), and Yes Fragile (DVD-A).I have to get the Yes album.
I have to get the Yes album.I highly recommend it.
As soon as I cues it up, what caught my ear was the air around the acoustic guitar intro to Roundabout. Beautifully recorded....the notes just float in space. Also, the vocals seem to have a lot of ambiance around them, like they were recorded in a large hall.
Overall, the classic Rickenbacher bass from Chris Squire is present in all its glory (in my youth I owned a Rick just because I thought the sound Squire got was so incredible).
Lastly, the pedal bass in Cans and Brahms is quite deep, particularly the last pedal note at the end of the song. At the right volume, you best have things in your listening room nailed down.
In general, this was another case of a MC Hi-Rez release allowing me to hear things in the mix that I did not know existed. I used to play this album over and over, trying to learn the bass parts. When I fired up the DVD-A, it was almost like hearing the music for the 1st time.
BGL
definitely find myself digging SACD a lot more due to the Peter Gabriel discs and the better jazz selection.Me too. The classical content on SACD is particularly good and usually sonically fantastic. Exhibit A - any disc from Channel Classics.
Let's see......My retro pension check should be in my hands soon.... the new Pioneer universal player is coming out in two weeks......safe to say I'll be "Bi" very soonMake sure you set aside a few bucks for an ICBM to cure the inevitable BM screw-ups! Then again, you may be one of those furtunate souls with 5 big-ass speakers AND a honkin' sub!
BGL
Doesn't the higher sampling rate create a higher potential for jitter distortion?No. In fact the SACD replication process is designed to minimize jitter. Its not about hearing in the upper frequencies so much as hearing MORE in the normal range of hearing, which by the way can be beyond 20k.
seems as if there's much more complexity in the analog recording setup, and D/A and analog circuitry on the playback end, to worry about compared to the respective digital formats.All digital formats must record in analog and convert to digital so it is really no extra work between DSD and PCM. In fact, many engineers feel DSD mic feed are more similar to the live event versus PCM mic feeds. That's one experiment that Michael Bishop at Telarc did as they were looking into new formats...
One thing to keep in mind is that analog circuits in the output area can have a huge impact on resulting sound.
I would encourage you to listen to a high end SACD player. I think you will find it sounds like a good turntable.
In general, this was another case of a MC Hi-Rez release allowing me to hear things in the mix that I did not know existed. I used to play this album over and over, trying to learn the bass parts. When I fired up the DVD-A, it was almost like hearing the music for the 1st time.It also allows you to NOT HEAR some stuff that was on the original album -- like lots of bits on 'Southside of the Sky', a track that's been remixed most radically. THere's also a bass riff or two on 'Roundabout' that have gone 'underground' in the new surround mix.
I'm not saying hte new mix is awful -- but it's certainly got its good an bad points. One thing it did was make me reappreciate what a geniius Eddie Offord was.
Make sure you set aside a few bucks for an ICBM to cure the inevitable BM screw-ups! Then again, you may be one of those furtunate souls with 5 big-ass speakers AND a honkin' sub!The only 'inevitable' BM screwups for a Pioneer uniplayer (I'm thinking specifically of the DV-45a) might be the crossover point of the bass management (too high for some tastes, and unchangeable) and its inability to do 'reverse' bass management (sending LFE to mains, only important for thsoe whiht full-range setups). Its other supposed bass management 'deficiencies', like the sub level adjustment, and the handling of various formats, have been highly misunderstood and misreported on this forum.
