High new with projectors need help please. (1 Viewer)
Robedsh
Knoxville
Robert E Shelby
I watch tv 24/7 I right now have a rptv but an looking into fptv .I need to know do I need to look for a certain type to be able to watch without turning it off for weeks at a time or do all need a rest period. I am a frugal person but I do know when I need to pay for quality. Also 1 or 3 dLp and are there any passive 3D units out there.Thanks again.
Robedsh
Knoxville
Robert E Shelby
I would not recommend a projector for your situation. Buy the largest TV you can afford.
Don't you sleep?[/QUOTE
I get sleep between going to the bathroom every 1 1/2. Now the room is would be using it is stays about 65 To 70° year round , would that make a difference on the projector overheating ?
Robert E. Shelby
bigshot
Stephen
Why do you leave your video going when you are sleeping or at work?
Martino
Santa Clara, CA
Martin O.
Most if not all projectors come with an internal lamp - and it has an estimate on how long it will last.
Looked up an example at projector people of a typical projector - Panasonic-PTAE8000U
Shows in Ecomode the following:
"(Brightness: 1920 lumens; Lamp life: 5000 hours"
So - running your projector 24/7 - roughly every 208 days you will have to replace the lamp - and they run for $341.00. That lamp time is calculated using "normal" running patterns - with cool off periods in between use - so you will probably average less than 208 days of lamp time.
They do make LED projectors - where the lamp life is longer - (LG model claims 30,000 hrs) - that will get you - if running 24/7 - 1,250 Days of operation...then you will have to replace the lamp.
The projectors are usually not designed to be run 24/7 -- so you would be better off getting something else.
Robedsh
Knoxville
Robert E Shelby
Most if not all projectors come with an internal lamp - and it has an estimate on how long it will last. So that's every 3 1/2 years that about average on technology changing.
blitz
