Larry Hoffman
- Jul 2, 2001
Hi All,
I have a Sony VL900 universal remote. I'm very happy with it, but I have a question. My DVD player (a Sanyo) is not pre-programmed, so I had to teach the Sony to run it from scratch. For simplicity, I programmed it so the functions are the same as the set-up in the user guide for players it is already programmed for.
There are a few functions on the Sanyo remote that I would like to program that are over and above the ones in the user guide. They are forward slow and reverse slow, as well as the bookmark, zoom and angle functions. (there are others, but I have never had occation to use them.)
Please let me know which buttons you recommend using for these functions. If you recommend using the number buttons, which did you use for each function?
Thanks in advance.
Larry
Thanks in advance.
Larry
