Mark_Sw
- Aug 16, 2003
Hi,
I'm getting ready to purchase a Paradigm speaker system and I'm not sure which one to go with. My choices are:
Option 1: A used (but full warranty) set of real wood Studio 100 V.2s with matching center and ADP-370 surrounds for $2400.
or
Option 2: A new set Monitor 7s, cc370, and mini-monitors as surrounds for $1375.
My initial budge was $2000 but I'm willing to stretch it a little for a good deal.
I plan on using an old Carver TMF-42 amp hooked through a Yamaha rx-v2300 to push the 100s if I go with option 1. I would use the rx-v2300 w/o amp for option 2. In addition I have a SVS PC+ 20-39 sub for the system.
I currently watch movies 80% of the time but I expect that to drop to 60% after getting a decent system.
Also, my ht room is about 1500 ft3 and has an open wall so it is not an ideal setup.
I really like the sound of the 100s but I would expect to for an additional $1000. The Monitor 7s (Option 2) sounded the best to me out of the systems I audition in my $2000 price range.
My biggest concern is the 100s will be overkill for my small ht.
Your help is appreciated!
Mark
or
Mark
