JohnSmith
- Apr 8, 2003
I was weary of cardboard subs too, but you would need to stand on the thing to crush it; even then I will assume it'll stand up to it.
The cardboard itself is highly compressed, try one of them packaging tubes (for posters)- they're tough SOB's- then imagine something several times thicker (1/4 inch) and I also believe the inside has a layer of epoxy for added strength (could be wrong though)
Sonotubes are used to mold concrete for underpasses in the states, and other columns. So if Sonotube can support concrete I don't think you have to worry about it for home use.
Also SVS tubes have a hard plastic outer coating under the cloth, so you dropping a drink on the side won't automatically ruin it (soften the cardboard) I would guess some DIY sonotube subs just have the cloth over the bare cardboard tubes.
I bought the SVS unheard from the states (live in the UK) you have the luxury of being able to return it (or try various models) since return shipping is much lower (plus don't pay import duty, taxes)
If you wish to buy a SVS sub made from MDF, checkout the box subs. But you'll pay more shipping, they cost more, are heavier, and are larger. They are also tuned higher at 25hz (the tubes are available in 16 & 20hz versions) the tubes offer lower tuned capability, plus the least amount of floorspace used (16.5" diameter)
