Ian Fotheringham
- May 29, 2014
Just tried turning on my JVC RX844v receiver...as you can see, power is reachign the front end, i can cycle through the sources using the jog wheel - but the display does not light up and there is no power to the speakers (when desired output is selected, volume cranked - nothing)...fuse is good of course - no obvious loose connections/burns....anyone have any thoughts?
