Help! Mitsubishi 720p RPTV and new HDMI DVD player = moire issues!
Discussion in 'Playback Devices' started by Kenneth Harden, Sep 9, 2007.
  1. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    We have had a 720p Mitsubishi RPTV for about 2 years and its been fine. Used a Denon 1720 DVD player with component video out and things have looked fine.
    However, bought a Denon 1730 for $50 because we needed the 1720 for elsewhere. Hooked up the 1730 with HDMI to the Mits and got everything setup and calibrated.
    Put in 'Zodiac' and started to watch. The picture was noticeable better (sharper, clearer image, looked almost as good as DirecTV HD) - but one big issue. LOTS of noticeable moire on things like clothing, window blinds, etc. Parallel lines were horrible.
    IIRC, there is an issue with a lot of HDMI DVD players and HDTV's - and IIRC, this was how it manifest itself.
    I tried 720p and 1080i and that didn't make any difference.
    Any advice? I LOVE the sharper, clearer picture, but the moire is very annoying.
    Thanks!!!
  2. JeremyErwin
    JeremyErwin Producer
    Feb 11, 2001
    3,218
    The problem is discussed here (scroll down to moiré)
    Try going into the menu, selecting display, and then toggling PROG-MODE to one of the other settings. Also, turn on progressive, if it's not already on.
  3. Kenneth Harden
    May 13, 2002
    1,365
    Progressive scan was/is on.
    Now the funny thing is - after wristing this post, I watched 'Blades of Glory' and 'Shooter' and both were flawless.
    No clue.
  4. JeremyErwin
    Feb 11, 2001
    3,218
    which PROG-MODE are you using? AUTO-1, AUTO-2, or video?
  5. Kenneth Harden
    May 13, 2002
    1,365
    I don't remember seeing that. What should it be?
    Thanks!
  6. JeremyErwin
    Feb 11, 2001
    3,218
    Try each of them in turn. AUTO-1 is the default, and most intelligent. AUTO-2 is best for films, and VIDEO is best for TV programs.
