whenimabillionaire
- Aug 22, 2016
- Sestrie
I need a 7.1 (or 5.1) surround sound system, and my budget is $500.
This is the receiver I was looking at: Sony STR-DN850 7.2 Channel 4K AV Receiver (Built-in Wi-fi & Bluetooth)
And I need a 7.1 system to complement it. Also, I'm not too sure if this receiver is that good. I've read reviews and they are great, and its NFC, WiFi, Bluetooth, AirPlay, etc. features are awesome, so that caught my attention. It would cost $200-$300 depending on where I buy it from. That leaves $200-$300 for the 7.1 system, but I'm not entirely sure if I would get the good quality with that budget.
Therefore, I also need a suggestion on a 5.1 system which has a receiver included (1 package). I was looking at the Onkyo HT-S3700. Is this the best sound quality I can get with my budget of $500? Also, would the Onkyo HT-S5800 provide much a difference compared to the HT-3700?
I did want a 7.1 system with receiver, but I know that would cost more, so could you also recommend me a 7.1 system with receiver for a maximum $600 which would give me the best sound quality.
Room details: It's pretty small at 112" x 77" with soundproofed walls. I don't know how much a difference 5.1 vs 7.1 would make.
