Kevin H
- Apr 22, 2000
I think my computer isn't recognizing the fact that i have a sound card installed right now. It was working fine, then crashed, I restarted (Windows ME) and now it doesn't see the sound card so all i get is an internal beep from the computer itself whenever a sound should be played by a program (such as the "message receive" in AIM.
In Winamp it says "MMSYSTEM002 A Device ID has been used that is out of the range for your system." When I go to the control panel and look at sounds, it says (grayed out, so that I can't select anything else) that there is no playback device chosen. I have restarted the computer and that did not work.
When I check Device Manager, there is no Audio tab there. Does anyone have any ideas?
