allan espinoza
- Jul 1, 2002
Well I have used the sound and vision dvd set up disc to calibrate the video on my television, but why are hd movie channels black levels so dark? I always have to turn up the brightness on my t.v cause its too dark, especially if it is a horror movie or a night scene. Another thing, is it normal on hd channels to have those motion artifacts, I think that's what they are called, like small squares or as if the picture gets broken up or something, it usually happens when there is a lot of movement like an action sequence, could it be my tv that does not do hd that well or could it be the hd provider which is comcast.
I have a sony kv-36hs420 in case you need to know, thanks
