HDTV ... 1080i 720p question
Discussion in 'Displays' started by Aaron_H, Nov 13, 2003.
  1. Aaron_H
    Aaron_H Agent
    Sep 11, 2003
    Pretty soon, I am planning to start doing some looking around for my first HDTV set. I had a few questions, though.
    I realize there are basically 2 HDTV formats being broadcast right now: 1080i and 720p. I was wanting to know if most HDTVs on the market just display 1080i? If I happened to buy a 1080i set, and was watching ABC (720p), what exactly would happen?
    Basically, what I want to know is, does a 1080i HDTV always upconvert 720p to 1080i? Is this image ever the true progressive on 1080i sets? When watching 480i (standard) on 1080i HDTV, what happens?
    ...really confused...
  2. Chad B
    Chad B Stunt Coordinator
    Jul 5, 2001
    Yes, most HDTV's display 1080i rather than 720p, but more and more of the newer fixed panel displays (DLP, LCD, Plasma) do 720p natively. Normally what happens when you watch a 720p broadcast on a 1080i TV is your HD tuner, cable box, or Dish receiver will convert the 720p to 1080i before sending it to the TV. There is usually a menu selection in the source component to set at either 1080i or 720p, and it converts everything to the resolution you select.
    Most 1080i sets will not even display a picture if they're fed 720p, but the few that do usually convert the 720p to 1080i. 1080i is not a progressive resolution; it's interlaced. However, the resolution's so high that it is usually not bothersome or noticed.
    When watching 480i on a 1080i HDTV, it is usually upconverted to 480p (or sometimes 540p or 1080i, depending on the set).
    Have fun, and good luck with your purchase!
