HDMI/DVI Retrofit Possible???
Discussion in 'Displays' started by Kevin Alexander, Jul 26, 2006.
  1. Kevin Alexander
    Kevin Alexander Screenwriter
    Apr 17, 1999
    I don't know if this has been covered before in the threads (if so, I apologize), I tried doing a search but didn't find the answer I was looking for. Anyway, I have a Panasonic PT-53WX42 HDTV w/ component inputs that I bought around 2002 before the inclusion of HDMI/DVI and was wondering if some sort of HDMI/DVI retrofit was possible for these slightly older sets. I wanted to look into buying a HD-DVD or BR player soon, and was exploring my options. I'd like to put off a new HDTV set for a while and was wondering if this is possible, and if so, for how much. Thanks for your help.
  2. JediFonger
    JediFonger Producer
    Feb 2, 2006
    YiFeng You
    no, not unless you get a transcoder... but it doesn't make sense because most HD-DVD/BR players have component outputs anyway. just use that for the time being. if ICT starts becoming the norm, then upgrade your HDTV.
