Matthew Brown
- Sep 19, 1999
I couldn't find the old thread with the search function so I apologize in advance for starting a new one on this.
The Mei Ah remastered HARD BOILED DVD is now available.
I haven't personally seen it yet as mine is in the mail.
While it probably won't be perfect, it is really the only one in print that is available for the US.
Generally the anamorphic transfers done by Mei Ah are acceptable even though not up to hollywood blockbuster standards. The sound is dolby or dts, no original mono. As long as the mix is subtle I don't mind. Subtitles are usually tolerable if you are familiar with HK imports.
I have seen this listed at HKFLIX.com but I am sure it is also available at pokerindustries.com. There are the HKbased etailers like dddhouse.com and hivizone.com also.
If you can wait a day to order, you can check out my site tomorrow for a special deal I worked out with hkflix for the visitors to my site. It will be $9.95 + s&h. For obvious reasons, I didn't put a direct link to the promotion. If the above violates forum rules at all, I will remove it. I just wanted to give HTF forum members the oppurtunity to the DVD for a good price.
I would have loved to get a review up before the promotion but I don't have a way to get advanced DVD's.
Matt
Matt
