Aaron:
Normally it's not the amp but you said that with the 9B on, and interconnects between the amp and premap installed but the preamp unplugged, you still get hum. If the amp picks up 60Hz from a ground loop, or through the interconnects (loose RCA plugs, speaker wire, etc.) then it will amplify the hum through the speakers. This is normal. However if the amp has a power supply issue the 60Hz could actually be coming from the 9B itself and this is not normal and can be easily checked by Bryston.
The test you did with the Parasound and Anthem is interesting. The Anthem has a two prong AC cord at the amp side if I remember correctly. Is the Parasound a three prong plug at the amp side?
