Good Home Theater Receiver (1 Viewer)
Rich_Mex
I am thinking on buying a receiver for my house. I am very new at this and I am sure there must be other options due to the price. I like the DENON AVR 5803A. I think it is expensive. Is there anything similar but much cheaper?
MuneebM
You asked if there was anything similar but cheaper, so I listed the cheaper models. The models I listed are all excellent receivers and you'll save a lot of money which you could use towards a separate power amp or other hardware.
John Garcia
NorCal
If you are looking at the 5803, I'd really consider separates. I'd never spend that kind of dough on a receiver. Take a look at Rotel, Adcom, maybe Outlaw, and I'm sure others. You might do well to throw out a budget and get some commentary on what is good in your price range.
Rich_Mex
I guess I can tell you what I have that I want to keep. LOL
1 pair of Klipsch RF3
I as every one else think I would like to spend the least and get the most. To give you an idea of my likings I like Yamaha and Denon amps. And my theory is: Louder is better.
I think the max of me spnding on an amp would be realistically 3 grand.
Any ideas?
Rich_Mex
Which is a good internet company where I can see prices and models of different components?
What do you all suggest?
acinstallation240
