Glad XP uninstall works....
Discussion in 'Archived Threads 2001-2004' started by Stephen Orr, Oct 31, 2001.
  1. Stephen Orr
    Stephen Orr Screenwriter
    Mar 14, 1999
    1,099
    You cannot truly appreciate the compatibility warnings Windows gives you until you actually install XP and find out what will absolutely will and will not work!
    I have a 466id eMachine
    Monday was a great adventure for me, as I installed the XP home upgrade over ME. I ran the compatibility software that came with XP, and for the most part I was okay. I have an older BIOS, but it did not seem to be a problem at all (and a quick check with eMachine tech support indicated that no problems had been reported). However, it didn't give me any real indication that my USB modem and my compact flash card reader drivers were not gonna work -- not to mention that my brand new Maxtor 40GB hard drive disappeared!
    As I was attempting to "install new hardware", I kept getting a prompt for drivers for a "parallel device". Was this my hard drive, and has anyone else run into this? (My biggest concern right now)
    My modem, it turns out, is an older Boca Research product, a TelePort 56k USB fax/modem originally built for Mac. I got it free after rebate as an OEM deal. I could not find any updated drivers for it, so I'm buying a new modem, a SupraExpress USB 56k that has Windows 2000 drivers.
    On the plus side, XP recognized and accepted close to 95 percent of my loaded software. I've already purchased and installed Systemworks 2002, and am waiting on the XP update for Easy CD Creator 5. I did find a Windows 2000 driver for my card reader, and still need updated drivers for my printer, an HP 722c (old, but extremely reliable!)
    I already installed the Windows 2000 driver for my card reader, and it seems to work.
    However, I did revert back to ME until I can resolve the USB modem issue, which will hopefully be by Monday. The XP uninstall went pretty quickly, about 1/4 the time it took to install it.
    Anybody else have some interesting adventures in XP Land!
  2. Camp
    Camp Cinematographer
    Dec 3, 1999
    2,301
    Any possibility you can get rid of the XP upgrade and get the full version? A clean install is highly preferred.
  3. Stephen Orr
    Mar 14, 1999
    1,099
    I am considering it. Actually, it seems that the upgrade gives you that option... You can choose either to upgrade and keep older settings, etc. , or install on a new computer. (I'm pretty sure you still have to start with an older Windows version.
  4. Jeff Kleist
    Dec 4, 1999
    11,267
    The parallel device was probably either your printer or Zip drive.
    Jeff Kleist
  5. Stephen Orr
    Mar 14, 1999
    1,099
    Don't have a Zip drive, and it had already asked for my printer software separately....
  6. Todd Hochard
    Todd Hochard Cinematographer
    Jan 24, 1999
    2,312
  7. Jacob_St
    Jacob_St Second Unit
    Jan 15, 2000
    259
    I'm assuming if you don't have a WinMe start up floppy you can't do a clean install? I only have a WinME reinstallation disc but no start up floppy.
  8. Matt DeVillier
    Matt DeVillier Supporting Actor
    Sep 3, 1999
    773
    Jacob,
    you can make a WinME boot disk by going to start->settings->control panel, opening the 'add/remove programs' panel, and clicking on the 'startup disk' tab at the top
    -Matt
    My DVD collection
    DVD Cover Art
  9. Jacob_St
    Jan 15, 2000
    259
    Thanks Matt!
  10. Mike Lang
    Mike Lang Stunt Coordinator
    Jun 5, 2000
    51
    Roxio's XP updates are out... http://www.roxio.com/en/support/ecdc...LT15T33IAVR3KQ
    Moderator, AVS TiVo Forum
