Greg Risley
- Sep 21, 1998
Unit is in great shape. I have had it for a little over 6 months. SACD is amazing. I am only selling because I got a new projector that has HDMI input so I want to get a player that uses that connection. If you have any questions or would like me to send pictures please feel free to cantact me.
I have OBM. $500 + free ground shipping in theUS.
Precision Drive™ 2 System with Dynamic Tilt Compensation : Past generations of Precision Drive were only able to compensate for warped discs by moving the entire optical block, which took more time and limited the amount of correction possible.
Some of the Specifactions
Sony's new Precision Drive™ 2 system simplifies the process by moving the lens-instead of the entire optical block-for faster and more accurate error correction.
Multi-Channel/Two Channel SA-CD Playback
Time Alignment for SA-CD
12 Bit Video DAC with 216 MHz Processing w/NSV
192 kHz 24 Bit Digital to Analog Converter
Dolby® Digital and dts® Optical/Coaxial Output
Variable Coefficient Filter for CD Output
Block Noise Reduction
Digital Noise Reduction (Motion Adaptive)
Video Equalizer with Video EQ Custom Memory
Gamma Adjustment
Title and Chapter Viewer
Advanced SmoothScan™ and SmoothSlow Modes
Instant replay and Instant Search
Full 3-2 reverse conversion
Inputs and Outputs
Component video output (Gold)
S-Video output (Gold) x 2
Composite Video Output (Gold) x 2
Coaxial Digital Output (Gold)
Optical Digital Output
Analog Audio 2Ch Output (Gold) x 2
Analog Audio 5.1 Ch Output (Gold)
RS-232C Control Port
Control S Output
Construction Features
Aluminum Front Panel Design
Anti-Resonant Chassis
Off Center Isolator Feet
Convenience Features
Advanced SmoothScan™ Mode
Custom Parental Control
Multi-Disc Resume (400 Discs)
Playback Memory (400 Discs)
Childloc® Feature (Tray Lock)
Picture Memory
Quick Setup
Start Up Screen
Screen Saver
Background Graphics
Video Off Feature
FL Display Off Feature
Video
Precision Drive™ 2 System : (Dual Lasers: 1 DVD/SA-CD, 1 CD)
Video Horizontal Resolution : >500 TV lines
Audio
Digital Output (kHz/Bit) : 96 kHz 24 Bit
Audio FREQUENCY RESPONSE (DVD, 96 kHz PCM) : 2-44,000Hz, ±1.0dB
Audio FREQUENCY RESPONSE (DVD, 48 kHz PCM) : 2-44,000Hz, ±0.5dB
Audio FREQUENCY RESPONSE (SA-CD) : 2-100,000Hz
AUDIO SIGNAL-to-Noise Ratio : >115 dB
Audio DYNAMIC RANGE : >103 dB (DVD); >99 dB (CD)
Harmonic Distortion :
Gamma Adjustment
Inputs and Outputs
Control S Output
Picture Memory
Quick Setup
Start Up Screen
Screen Saver
Background Graphics
Video Off Feature
Video
Audio
