Bill Balcziak
- Aug 4, 1999
THE BLURB:
The KSW-12 powered subwoofer uses a sturdy Klipsch bass woofer and Santoprene® rubber surround driven by a 440-watt, high-efficiency amplifier to fill your room with the ultra-force low frequency energy that breathes life into music and movies. The enhanced-performance, down-firing design and sonically tuned port enclosure contribute to the powerful, yet precisely accurate high output, delivering bass so low and strong that you feel it even if your human ears can’t hear it.
THE SPECS:
FREQUENCY RESPONSE: 26Hz-100Hz±3dB
MAXIMUM ACOUSTIC OUTPUT: 113dB SPL 1/8 space, 1 meter
ENCLOSURE TYPE: Bass reflex via rear-mounted port
TYPE: 12" Bass reflex, tuned port enclsosure
AMPLIFIER: Class A/B discrete MOSFET outputs
AMPLIFIER POWER: 440 watts dynamic power
AUTO POWER ON: 2 Second ON delay, 15 minute OFF delay
LOW PASS CROSSOVER: Continuously variable from 40-120Hz, 24dB/octave slope above 120Hz
INPUTS: 2) Line level/LFE RCA phono jacks and 2) High level speaker terminals
OUTPUTS: 2) High level speaker terminals, high pass filtered at 100Hz, 6dB/octave slope
PHASE: Switchable 0 or 180 degrees
DRIVE COMPONENTS: Subwoofer system using one 12" (30.5cm) down-firing, fiber-composite cone woofer
WOOFER: K-1071-K 12" (30.5cm) Fiber-composite cone
DIMENSIONS (H x W x D): 17" (43.18cm) x 15" (38.1cm) x 15" (38.1cm)
WEIGHT: 35 lbs. (15.9kg)
This subwoofer is in very good, lightly used condition. It comes with the manual, original box and all packaging. The KSW-12 is an extremely powerful sub with all the bells and whistles.
Priced to sell! $225 plus UPS shipping cost to your location. Please feel free to e-mail me for more information.
(For what it's worth, I am a +16 trader at HTF and a 288+ EBay seller.)
