Front Page Question
Discussion in 'Archived Threads 2001-2004' started by Andrew V, Nov 3, 2001.
  1. Andrew V
    Andrew V Stunt Coordinator
    May 11, 2000
    197
    I want to have it when I click on an image on my website it will open up in a new window that is sized to fit that image. How do I go about doing this?
    I’m completely new to front Page, so please explain everything. I'm using Front Page 98. Thanks in advanced.
    ~Andrew~
    ~Pronto Programmer~
    AIM SN: FFU Productions
    ICQ #: 21603991
    Home Theater Pictures
    Equipment List | My Growing DVD Collection
  2. Andrew V
    May 11, 2000
    197
    Anybody? [​IMG]
  3. JasonD
    JasonD Agent
    Mar 29, 2000
    47
    Hello, I have Frontpage 2000 and 2002 so I'm not sure if the following will help. Did you try clicking on the image and choose "ADD URL" or whichever command allows you to add a URL? Try doing that. You should have the option to allow the URL to open in a new window or within the same web. Choose "new window". I hope this helps. Good luck!
  4. Kelley_B
    Kelley_B Cinematographer
    Feb 27, 2001
    2,324
    why not just hardcode that into your page? actually i think you might need javascript to do this......i hate front page, so i can't tell you, but if notepad.exe is your best friend.
  5. Andrew V
    May 11, 2000
    197
    Jason: Thank you for your help. That worked like a charm. Now I just need to figure out how to resize that new window. Any suggestions?
    Kelly: I don’t really know the code to manually enter everything which is why I’m using Front Page.
    ~Andrew~
    ~Pronto Programmer~
    ICQ #: 21603991
  6. Jesse Leonard
    Jesse Leonard Second Unit
    Jun 8, 2000
    430
    Here is the basic javascript you need to use. Just click on the edit button on this post to view the code:
    < !-- Begin
    function popjack()
    window.open('/pop1.html','popjack','toolbar=no,location=no,direc tories=no,status=no,menubar=no,resizable=yes,copyh istory=no,scrollbars=yes,width=400,height=600');
    YOUR LINK HERE.
  7. Andrew V
    May 11, 2000
    197
    Jesse: Thank you for the script but how would I impliemtn that into Front Page? Please excuse my ignorance but I'm a novice at this stuff. [​IMG]
