floppy-not-working-why?
Discussion in 'Archived Threads 2001-2004' started by Rich E, Aug 13, 2001.
  1. Rich E
    Rich E Agent
    Oct 19, 2000
    36
    In the process of fixing my cdrom my floppy drive stopped working. I confess I'm a bit of a novice when it comes to actually taking these things apart and fiddling with the insides.
    anyway, I've tried the ribbon cable which connects the drive to the mother board in several different positions and none of them seem to work.
    Each time I re-start the computer the green light on the drive is either on or off, regardless of this each time I click on the floppy icon the drive does not respond.
    Any help would be greatly appreciated.
  2. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    First of all, check the most obvious thing - cabling.
    I've had this before. Scratched my head for an hour before realising the connector cable was attatched to the floppy drive the wrong way up. It's easy to get it correct on the motherboard because of the slot groove, but sometimes the interface on floppy drives doesn't make it clear which way around it's supposed to go.
    Try it. Worth ruling out if nothing else.
  3. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    The ribbon cable has a colored stripe on one edge. This edge indicates the "Pin 1" side of the connector. The pin numbers may be marked on the motherboard, and on the drive pin 1 is on the closest edge to the power connector.
    If the floppy drive light stays on continuously, this usually means the cable is on backwards.
    KJP
    MAR: Mutilated Aspect Ratio. Opposite of OAR. Describes the MARring of film releases by not releasing them in the original aspect ratio.
