Experence with these ports? (1 Viewer)
Allen Ross
Hey All,
I just got the new PE clearance catalog and after perusing it for a bit i noticed these really nice ports.
has anyone bought any of them and what has their experience been with them. I don't have any plans that need them right now, but for the price its kinda hard to pass up. I am a little hesitant to buy them in that am not sure how well they stay in, the screw-less install is a bit weird, also they seem to be fixed length unlike the Areo Ports.
Allen
Ryan T
I used one in my latest project.
http://www.geocities.com/ryatod/sub.html
It stays in just fine. I used a bead of caulking to hold mine in. Overall I think its a steal to get a dual flared port tube for that price. The only thing is you cant adjust the length any so your stuck with that one tuning point.
Ryan
Geoff L
Geoff
They work fine.
You can cut it also, you just loose some of the flare on the smaller flare end is all...
Have not used mine yet, but Frank C. did, and he said they where nice and very tight. Coud always run a bead of non adhisive caulk if your unsure of it being air tight....
For the money, good flare... Your cut out is going to make or break the good seal on these. and if you screw that up, there is always a way to still make it work, with-in reason....
Larsenv
