Energy HT vs. Definitive HT
Discussion in 'Archived Threads 2001-2004' started by Jim Meeks, Dec 8, 2001.
  1. Jim Meeks
    Jim Meeks Extra
    Dec 7, 2001
    Ok, here's my NEW dilemma. You may have read my pvs. post regarding the e:XL series questions. I have a new wrinkle.
    Just finished auditioning a Definitive Tech set up as follows:
    ProCenter C2 (center) $299
    ProMonitor 100 (front l/r) $350/pr
    ProMonitor 80/BP1.2x/BP2x (rear l/r) $225/350/500
    ProSub 80/100TL/200TL (sub) $350/450/550
    I am comparing this against the e:XL series as follows:
    e:XL C2 (center) $261.66
    e:XL 26 (front l/r) $562.32 /pr
    e:XL 16 (rear l/r) $222.32 /pr
    e:XLS 12 (sub) $552.70
    Now unfortunately, I cannot compare them side by side, so I must ask YOU, good forum members, for your insight.
    The differences as I see them, are around $100, and size of the speakers. (The DT's being much smaller)
    -is there a large difference in quality between these two setups? (in the stores I demo'ed, the Energy was just below the top of the line, while the Def Tech setup was 'entry level' at the other store)
    -regarding the Def Tech, I assumed the highest end for this price comparison, i.e. BP2x's for rears and the 12" sub. I listed the other models in case you feel they would round the system out just as well.
    -pros and cons for each? final recommendations?
    Also, I have seen a few receivers I like. Considering your above choices, which receivers fit the bill? The Marantz 5/6200 came with high praise, with Onkyo, Denon and Outlaw each receiving votes.
    Thanks so much for your assistance!
  2. Ricky c
    Ricky c Stunt Coordinator
    Aug 28, 2001
    I can only tell you what i have.I have the Def.Tech.100's all around with the pro100 center and the 200tl sub.I have them powered with a Marantz sr7000.They are probably the best sub/sat system on the market.They sound alot bigger than what they appear.The only thing is you should wire them according to recommendations.Which is wire speakers to sub and lfe thru receiver.Mains to large rest to small and sub yes.You get the best of both worlds.You won't regret the's.I guess i'm partial to them.
  3. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    I quite like most Energy speakers but I find the ex:L line really isn't very musical compared to their old speakers. If music is important to you I'd maybe consider another set...of course thats just my oppion
  4. JeremySt
    JeremySt Screenwriter
    Aug 19, 2001
    My system:
    EXLC2 center
    EXL26 fronts
    EXL16 sides and rear
    Martin Logan Descent Subwoofer
    Denon AVR3802
    Denon DVD3300
    That said, and having dirctly compared them toall sorts of def-techs, I can confidently say that the EXLs handily beat the DefTechs. My 2 cents.
    The EXL series is Energys entry level speaker package (besides their sub-sat systems "Take" and "Encore") Above the EXL is conissuier and the $1500- $4000/pair Veritas. For the price, I think the EXLs cant be beat. But to be honest, I have always hated the sound of Defenitive speakers. Kinda wimpy. I plan on upgrading soon to veritas or maybe Martin Logans
