Brent Hutto
- Aug 30, 2001
My brand-new 36XBR800 has a little more red push than I can get used to. I don't (yet) have a service manual and am loathe to go into the service menu while the set is under warranty. However, if I knew how to go in, change that one parameter (AXNT?) and get back out again safely I would probably do it.
I've seen posts for various XBR's but am hoping that someone familiar with the service menu for the 36XBR800 might be willing to post idiot-proof instructions for this one, tiny change. Or should I just forget about it since I'm so nervous. It's my impression that one false movie in the service menu and you can do unfixable damage that also happens to void the warranty.
With my original Panasonic RV31 the red on Avia's color test screen was only +15% (green and blue were slightly below zero). However, for some reason with my new progressive-scan RP82 the red is up to +25%. I noticed the unnaturally ruddy faces pretty often with the old DVD player so if this one is worse, well that isn't acceptable.
