Evan M
- Sep 17, 2003
I have a Kenwood DV-705 DVD Player (LINK (Crutchfield) )
It is hooked up via component cables to my Toshiba 50" TheaterWide HD television.
The problem is during playback of DVDs, there is a white line that starts on the right side of the screen and goes halfway or a little more across, which shows up every now and then. It is kinda sporadic and happens regardless of what disc I use and does not always happen at the same points during playback. It'll just pop on the screen for a split second or so and do it every few minutes at different spots on the vertical (IE: Sometimes towards the top, sometimes in the middle, sometimes toward the bottom)
Any ideas on what this is, what causes it, or how to fix it?
