Mario F
- Dec 30, 2003
1st off this is a great site and I have learned a lot by reading these forums, I am new here.
Ok, so I my TV in the Wood console that I had finally died. The dam thing is like 20 yrs old but had some good times with it, so wifey says to buy a new TV. I bought this TV TOSHIBA 46H83 Wide Screen. It is really sweet, now hooking the dam thing up with a VCR and a DVD Player is giving me a headache. I followed the directions on the hook up and got everything going. I have a DVD system(CHEAP system) but it works NORCENT DP1800. I also purchased some Component cables and the Audio cables Monster Video® 2 Component Video Cable
Now when I hook them up I get some sort of noise on the DVD screen, but on the VCR screen or the TV mode I get no noise. So I disconnect the Component Wires and hooked up the S-Video wires and the audio in on the DVD Player and I get no noise and the Picture looks perfect. Noise meaning I see whats on the screen but I get diagnol lines but transparent. I tried hooking the Component wires to another HD connection meaning HD 1 and HD 2 but still the same results. So I then Seperated the power wires from all of the components and put on the Video and audio wires together in the back of the TV but still get lines, I moved wires around and still the same thing. Any other suggestions. If I can't get it to work then I will settle for the S-Video connection.
