DVD-Audio from a DVD-ROM
Discussion in 'Archived Threads 2001-2004' started by Ash Williams, Oct 20, 2001.
  1. Ash Williams
    Ash Williams Second Unit
    Oct 16, 2000
    256
    Is there any software out there that will allow you to hear the Advanced Resolution mix off a DVD-Audio disc using your DVD-ROM drive? I have a number of software DVD players and none of them even recognize another audio format other then the Dolby Digital track off DVD-Audio discs. Any help would be great. Thanks
  2. Camp
    Camp Cinematographer
    Dec 3, 1999
    2,301
    Isn't there some minor physical difference between DVD and DVD-A discs?
  3. Ash Williams
    Oct 16, 2000
    256
  4. Jeff Kleist
    Dec 4, 1999
    11,267
    As long as you have software that will play DVD-A, I don't see why it wouldn't work. At the very least the DD 5.1 track on the disc should play
    Jeff Kleist
