KrisPfeiffer
Grip
- Jun 3, 2002
Hi.
I'm nearing the end of my little home theatre construction project downstairs, and it's time to consider the subwoofer.
The sub will be concealed behind a false wall that also contains the other speakers. The area between the false wall and the basement wall is about 40" deep.
I'll be building my own sub, as only one that I design will be able to fit back there. There is a 15" x 15" hole that will allow the driver to fire into the room.
So far I've been looking at sealed systems only (e.g., a Madisound NHT 1259 kit). Due to the confined space that the sub will be in, am I indeed limited to sealed systems? What kind of impact would a ported system have behind a false wall? The sonosub sounds interesting, but I think I may have already excluded that possibility due to my wall design.
You can take a look at the wall here - http://www.avsforum.com/photopost/sh...t=1&thecat=500
The sub opening is on the farthest left-hand side, next to the taller, rectangular looking opening.
Kris
Kris
