DIY Sub help (1 Viewer)
Tyler
How do you put a subwoofer cabinet together with glue or screws ?
P.S
Any body know where some links are on building a shiva subwoofer ?
Any imput would help me out alot THANKS.... :)
Seungsoo Hwang
Well I can only give you the simplest of answers. First, you must decide what kind of joint the cabinets are going to have. Butt joints are the easiest, just butt the wood next to each other. This is glued with various glue like Elmers, titebond, polyurethane, etc.. and either held together with clamps, glued/screwed, both, etc..
Look at the upper left hand corner of the screen for "sonotube subwoofer links"
NHCondon
