DIY sealed subwoofer
Discussion in 'Archived Threads 2001-2004' started by john_focal, Aug 27, 2002.
  1. john_focal
    john_focal Agent
    Aug 22, 2002
    hi folks. I hope this isnt too redundant, as I see a lot of questions from people contemplating thier first DIY project.
    I am planning on building a sealed cabinet sub, either 10 or 12". Initially I am planning on this woofer--> .. and a well built cabinet of either MDF or marine ply. A 250 watt plate amplifier will be powering this sub.
    So my questions:
    For a sealed cabinet, are there more suitable drivers available?
    Is there reference material available for bracing techniques for sealed cabs, or should I just be looking at the premade kits for an idea on what it should look like?
    Considering the wattage and speaker, is the upgrade to marine plywood worthwhile? Or is that preferred for larger situations?
    Thanks in advance!
  2. Jon Torres
    Jon Torres Second Unit
    Dec 30, 2001
    You can take a look at the different sealed designs on adire's website to get an idea on bracing. You could also look at Patrick Sun's traditional box.
