Cynthia Binder
Grip
- Aug 31, 2003
I am doing a remodel and am installing a distributed audio system throughout the house. I am using 9 pairs of Phase Technology CI-40V speakers in separate rooms, and two pairs of Phase Tech Spacias in bathrooms.
I am using Ixos 14-4 speaker wire. Since I have never run in-wall stuff before I have a question about how you handle the wire. After you get to the first speaker in a zone, do you just leave a loop and continue on to speaker #2 and then make connections after drywall, or do you strip off the jacket and separate the pairs at the time you run the wire?
My second question regards speaker placement. The factory support techs say you can use these speakers in-wall or in the ceiling. Which provides better sound? How do you determine best placement in a room? If you install in the wall, does height matter? What about installing speakers in the wall above cabinets?
Any helpful hints on a whole house system are appreciated!
Cynthia
Cynthia
