Direct TV No sourrand Sound Help Please
Discussion in 'TV Shows' started by Danny_1, Feb 20, 2007.
  1. Danny_1
    Danny_1 Auditioning
    Feb 19, 2007
    8
    Hi all Does Direct not work with Sourrand Sound?
    I have a RCA guide plus television (not hdtv)
    Sony S-Master Didigal amplifier sourrand sound.
    It works fine as a DVD player but with direct tv only one wall mount speaker and the base amp. works.we have tried everything the manual says. We thought it might be that Direct TV don"t have sourrand sound. Please help if.I called Direct there not any help so I come to the pro"s. Thank You Danny
    OH yeal I also have a DVR hooked to it
  2. BigJim
    BigJim Agent
    Feb 19, 2007
    43
    2
    Jim
    What model DirecTV receiver do you have? Is the DVR in addition to the receiver, or is it a DirecTV DVR?
  3. Charlie Campisi
    Charlie Campisi Screenwriter
    Aug 20, 2004
    1,612
    37
    To get true surround sound, you need to hook your directv receiver to your AVR with digital cable, either coaxial digital or digital optical. You then have to go into the directv receiver's menu and activate dolby digital.
    If you don't use the digital audio connection, you can get simulated surround sound if your receiver supports dolby pro logic or dts neo or another simulated surround sound. For this, you only need the red/white stereo cables.
    In addition, not all shows are broadcast in surround sound. Most but not all of the hd programming is. Other than that, you mostly get true surround sound occasionally on the premium movie channels.
  4. Danny_1
    Danny_1 Auditioning
    Feb 19, 2007
    8
    Its a Direct DVR from direct Sat. DVR and reciver is one unit. Danny
  5. Danny_1
    Danny_1 Auditioning
    Feb 19, 2007
    8
    Ive tied it on many channels and NASCAR no luck Danny
  6. BigJim
    BigJim Agent
    Feb 19, 2007
    43
    2
    Jim
    Which specific model?
    I have the DVR R10 which is a Tivo unit. I have the sound connected with the digital (optical) cable, and it works just fine in surround.
  7. Danny_1
    Danny_1 Auditioning
    Feb 19, 2007
    8
    Its a DVR R10 Danny
  8. BigJim
    BigJim Agent
    Feb 19, 2007
    43
    2
    Jim
    Are you using the Optical cable, or the White & Red RCA Jack cables?
  9. Danny_1
    Danny_1 Auditioning
    Feb 19, 2007
    8
  10. Charlie Campisi
    Aug 20, 2004
    1,612
    37
    I've already answered your question in post no. 3.
  11. BigJim
    BigJim Agent
    Feb 19, 2007
    43
    2
    Jim
    I've never tried that connection. Did you read Charlie Campisi's post above?
    ya beat me to it.
  12. Danny_1
    Danny_1 Auditioning
    Feb 19, 2007
    8
    Yes I read it but don"t understand.I just called local direct tv here and he says that Sony S Master will not work with it. wants $100.00 to come out and check it. We are on disability and can"t afford that. Seems like Sony S master should work I just bought it new from Wal Mart. Do I need to take it back? Danny
  13. Danny_1
    Danny_1 Auditioning
    Feb 19, 2007
    8
    Found the problem BROKEN WIRE to one speaker. Thank You Danny
  14. BigJim
    BigJim Agent
    Feb 19, 2007
    43
    2
    Jim
    But it still worked with the DVD player?
  15. Danny_1
    Danny_1 Auditioning
    Feb 19, 2007
    8
    I guess one speaker had a broken wire. We recalabrated the speakers and changed the settings and now its working do Not know why tho. Thank you All Danny
