Mike Pollmann
- Feb 14, 2000
I'm on the verge of buying a new receiver, and I've narrowed my choices down to the following: Denon 2803/3803, Sony DA4ES, and the Pioneer 45TX.
I'm very interested in the MCACC capabilities of the 45TX due to my abnormal room. Everything I've read on here makes me think it would be a great idea for optimum sound. The only problem with the 45TX is that it doesn't really have enough digital inputs. With only 2 optical inputs on the back, I can't see how I'd hook up my system.
Here's the equipment I need to hook up via digital inputs:
DVD Player (optical only), DirecTivo (optical), Xbox (optical), PS/2 (optical).
The Sony and Denon models both have 4 optical ins, and would work fine. But that darn MCACC sounds so appealing! The room I'm in is a large L shaped room, where the HT is in a large portion of it (a 12 x 12 square), with the left side being open to the rest of the room. I'm sure this non-ideal layout would benefit from the MCACC.
So, what do you guys think? Is it worth getting the 45TX and having to rely on a switchbox for optical inputs? I was hoping to eliminate a switchbox I currently use for a/v and have the receiver do everything. Or should I go with a Denon or Sony?
(As an aside, I'm also in the middle of weighing the pros and cons of authorized/non-auth purchases. I have about $800 or so to spend on this receiver, so could get any of the units for that from non authorized sources. If I decide to go the "correct" way I'd probably end up with the $800 2803. Unfortunately, the only store in town that carries the Pioneer & Sony is a bit 'snooty.' I'm never taken seriously when I go in there, I feel like I'm fighting the salesmen, etc. I honestly don't want to give them my business. The fact that they have a huge Bose display right when you walk in the door deters me even more. Would appreciate comments on this as well.)
Sorry for all the rambling. Help would be appreciated!
Mike
Mike
