Pete_Jr
- Oct 21, 2001
I know you need an additional amp for the 2 surround backs but can you use an old receiver to do the job? Or do you have to buy an amp like the Denon POA-5200?
If you can use an old receiver(Sony 110Watt Dolby Surround)How would I hook it up?
Also without the back surrounds hooked up do you still play DVD's with EX on the Surround EX setting or just the Home THX? Will there be a difference?
Pete
Pete
