Jacqueline C
- Feb 10, 2003
If your vcr has composit outputs only and you connect those to a receiver and everything else has s video outputs, can you still run s video cable from the reciever to the tv?
If your tv is HDTV ready and it has 2 sets of component inputs, and your receiver doesn't have any, are you losing anything by connecting the dvd directly to the tv with component cable and running digital coax cable from dvd to receiver? Or is shelling out the big bucks for the reciever to have component inputs really necessary?
It seems to me that if you have 2 component inputs on the tv you can run the dvd and the HDTV receiver(not sure if that is what they are called) into the tv directly when you get one but please correct me if i'm wrong.
What is the best way generally to get good sound when you are watching regular television? I see outputs for red/white rca cables on the tv labeled to audio amp but nothing more complex.
Thanks to any who reply
