Bart_R
- Nov 25, 2002
Hey everybody,
My 'problem' should be very clear from the title alone, but let me give you some background info...
My speaker setup is as follows: I have a (jamo) passive sub system (2 sattelites connected to a sub) acting as fronts, and similar (jamo) sattelites (without a sub) for rears (and an old mid-size panasonic speaker for center, and a sony sa-wm40 sub). I have them all set to large on my receiver, simply because it usually gives me the best sound. I haven't had problems so far, but after reading some posts on the forum, I've been wondering if it isn't bad for my speakers. Can anyone shed a light here?
Even though my speakers seem to be doing fine, I don't wanna damage them in the long run of course. I'm especially concerned about the rears, cos I think that since the front sattelites are used with a sub that they can be considered large. But I might be wrong.
(Oh and for my sub it's no prob btw. I have a 'plus' subwoofer setting on my receiver (pioneer vsxd510), which means I will get the appropriate bass sounds from my sub no matter what the speaker settings are)
So, any thoughts on this one?
Later,
Bart.
Later,
Bart.
