Dave Milne
- Jul 2, 2001
I've tried to surf through the plethora of DIY sub info in this forum but bogged down under the mountain of posts.
I'd like to build a front (main) sub to complement my LFE sub (which is built into the platform for the second row of seats in the theater... it makes a nice buttkicker as well as LFE sub). The LFE sub uses a JBL 2245 18" driver in 10 cu.ft. vented, equalized. It's flat to 22 Hz and puts out 121dB at 300 watts.
Bottom line: What's the best DIY sub assuming that driver cost is not an object -well, OK, under $1000.
Cabinet complexity is also not an object (PR, high-order and compound designs OK) but total volume is less than 8 cu.ft.
Electrically assisted is OK, i.e. sixth-order vented, equalized.
Power will be 550 or 750 w (I have a couple of bridgeable amps available)
By the way, my Lexicon MC-12 pre-pro has fully adjustable crossovers and separate delays for the LFE and main subs so that's not a problem.
