Computer messes up convergance
Discussion in 'Archived Threads 2001-2004' started by NateF, Sep 27, 2001.
  1. NateF
    NateF Stunt Coordinator
    Aug 22, 2001
    63
    OK, so I've had my ECP4101 for a while now, but I've never gotten around to hooking it up to my computer (been watching TV & DVD through a DVDO) and that works fine. But last night I decided I wanted to watch the Lord of the Rings trailer on my projector, so I plugged my laptop into the projector... and the convergance is way off. Almost like watching it in 3-d. What's up with that? It should be almost identical to the feed coming out of the DVDO, right?
    Any help or suggestions would be appreciated.
    -Nate
  2. SteveMc
    SteveMc Stunt Coordinator
    Feb 3, 2001
    230
    How are you connecting the devices to your projector? If you are using a different input on your projector for your laptop chances are it just hasn't been converged yet. Many displays have different color and convergence settings for each input. I can't think of any reason your computer could mess up convergence.
    Crash
    "I don't even own a gun, let alone many guns that would necessitate an entire rack."
    Help us get the Friday the 13th films-UNCUT. Click Here or here
  3. Abdul Jalib
    Abdul Jalib Stunt Coordinator
    Dec 27, 2000
    175
  4. Neil T
    Neil T Auditioning
    Jan 28, 2000
    6
    I have an ECP 3100 hooked up to my PC and I can tell you that the convergence needs adjusting for every different refresh rate and resolution. Are you familiar with programming the muti-channel inputs in the ECP's menu, if not hit HELP and go to option 4 and follow the instructions. Once you have assinged another channel preset to the PC you can re-converge the PC without messing up your settings for the DVDO.
    Neil.
    The only bad opinion is no opinion.
