Computer Advice?
Discussion in 'Archived Threads 2001-2004' started by Anthony_J, Nov 12, 2001.
  1. Anthony_J
    Anthony_J Stunt Coordinator
    Jul 31, 2001
    242
    I need some help. I'm having a friend of a friend build a computer for me, and he gave me some details on pricing, components, etc.
    Here's his suggestion:
    Either an AMD Athlon 1700+1.47GHz, or a 1.7Ghz Pentium 4.
    Either 512MB Ram with the Intel or 1Gig Ram with the Athlon.
    Plextor 16x10x40x CD-RW
    Leadtek WinFast TDH GeForce3 Ti 200 64MB DDR AGP
    Hercules Game Theater XP Sound Card
    Sony 16x DVD/52x CD-ROM
    IBM 20GB HD (for applications)
    Western Digital 80GB HD (mainly storage)
    3Com Ethernet Card (for cable access)
    The system would cost $1,750 for the box only with either processor (because the Intel box will get half the RAM).
    The price seems rather prohibitive because I'll still need to get a monitor, and all peripherals, which can easily add up to another $600-$1,000.
    I was hoping for some suggestions as to how I can cut the price by about $300-$500 without sacrificing tons of functionality (e.g., different sound card, video card, etc). I like the machine, but don't know if I'm willing to pay almost 3 grand (maybe I'll ditch the graphics/sound capability and get an X-Box instead)
    I'll be using the computer mainly for business apps/games/CD burning. I have a dedicated home theater setup, so chances are slim I'll be using the computer to watch DVD's, although I'm not sure how much it will save me to swap the DVD drive for another CD drive. Also, I won't need any speakers because the sound card has an optical out that I can hook up to my receiver.
    Thanks for any input.
  2. Joel Mack
    Joel Mack Cinematographer
    Jun 29, 1999
    2,317
    Where are you getting your prices from? I just priced out the items you mentioned (the AMD/1GB RAM option), and came up with about $1100 from newegg.com...
    "The internet is a place where people from all over come together to
    bitch about movies and share pornography."
  3. DaveF
    DaveF Moderator
    Mar 4, 2001
    17,497
    1,382
    One Loudoun, Ashburn, VA
    David Fischer
    Anthony -- it would help if you gave your price limit for the total system. Also, what do you use your system for? The system you list is quite powerful, and really is overkill for word-processing type business uses and for occaisional gaming.
    If you're not a serious gamer, scale back on the video card and sound card.
    If you don't do video editing, high-resolution image editing, or install many large appplications, you could go with less than 100GB hard drive space.
    If you don't watch DVD movies on your system, you could drop the DVD drive.
    If you don't run many programs at once, or do memory-intensive tasks (image editing), you can reduce the RAM to about 256MB or even 128MB.
    If you don't need the power that system provides, you can get a very capable system for about half the price. For comparison, here is a mid-range Dell system, including monitor.
    Price: $1380
  4. DaveF
    DaveF Moderator
    Mar 4, 2001
    17,497
    1,382
    David Fischer
    Also, what about warranty issues? If your friend builds it, will he also be your "technician / customer service"? If this is a business computer, and your friend might not be able to provide tech-support when you need it, it may be worthwhile buying a retail system, for the tech support.
  5. DaveF
    DaveF Moderator
    Mar 4, 2001
    17,497
    1,382
    David Fischer
    Hope I'm not overwhelming you [​IMG]
    Here's a power system, roughly equal to your listing. There are some benefits to building your own system, but this should give a sense of features for a similiarly priced retail system.
    Price: $2,900
  6. Anthony_J
    Jul 31, 2001
    242
    I haven't really priced the whole system myself, except for the areas that I thought would cost a lot of money (audio/video cards, DVD/CDRW drives) for the purpose of seeing if I could come up with places to cut some costs. (I priced at Amazon and other major retailers because I didn't know about newegg.)
    He'd also use an Abit KG7-Lite AMD761 Socket A 2DDR UDMA100 ATX motherboard for the AMD system (and a heatsink and fan), or an Intel D850GBC Socket 423 Pentium-4 ATX board for the intel.
    The Ram is Kingston, either 266Mhz DDR PC2100 CL2.5 RAM for the AMD, or PC800 RAMBUS RDRAM for the Intel. The case is an Aopen HX45 ATX MID Tower case with 300 W Power supply in either case.
    I'll go to Newegg now and see how much the system would be if I were to buy the components myself. He might be charging some extra for himself, but from what my friend told me, he's supposed to do a great job (eg., he'd overclock the Athlon for me, and make sure each component is 100% efficient.)
    I used to be into hardware, but haven't kept up to speed on the newest and greatest, and I don't really feel like relearning how to put this stuff together. When I was following this stuff, Internet retailers weren't a reliable option, no normal consumer heard of USB, and Pentium had just broken the 200 mhz barrier. That goes to show you how far removed from the PC arena I am.
    Thanks!
  7. Anthony_J
    Jul 31, 2001
    242
    Wow, thanks guys.
    I was considering buying a Dell system, but there's some allure to having a "homebuilt". In terms of pricing, I'd like to keep it around $2,000, but that's negotiable.
    I just figured that the days of the $2,000 PC were over and there'd have to be some ways to cut costs. I'm trying to have my cake and eat it, too. Although I'm not a die-hard gamer, I like having a system that can handle anything I'd like to play. Same with the DVD drive. That's why I'm looking for mid-level components with similar capabilities to the components listed (i.e., GeForce 3, digital 5.1 support, etc.)
    Maybe I'm trying to get too much in one system. Oh well, the drawbacks of being a cheapskate who wants the latest stuff.
    The way I figure, the less I spend on this computer, the more I have to buy DVD's, or new speakers, or a new TV...
  8. Rob Speicher
    Rob Speicher Supporting Actor
    Nov 24, 2000
    935
    What games do you play? A GeForce3 might not be necessary, and could save you some money going to a high end GeForce2 instead. I got a Gladiac 920 a few months ago, and the improvement in the current games wasn't very noticable, with the exception of Quake3.
    Quake3 gets 110+ FPS in 1024x768 32bit/full effects
    Older engines like Half-Life and EverQuest get around 60 FPS in 800x600, 40-45 FPS in 1024x768.
    If you're still playing older games like Half-Life, you probably wouldn't notice the difference between a GF2 and a GF3. So far, for some reason, it seems like the older games treat a GF3 like a plain old GeForce. If you play Quake3 pretty often, though, it's definately noticable, and probably worth it.
  9. DaveF
    DaveF Moderator
    Mar 4, 2001
    17,497
    1,382
    David Fischer
    Actually, the best thing would be to tell your friend: "I've got $2,000 and I need a computer for these things primarily and those things secondly. What should I get?" It looks like he knows his stuff, for high-end. Let's see if he can cope with financial contraints [​IMG]
    That said, here's more of my opinon...
