Jay Mitchosky
- Sep 6, 1998
Does anyone have a technical explanation regarding the Sharpness control of the Pioneer ELITE CLD-9 laserdisc player, particularly in comparison to conventional sharpness adjustments?
To elaborate, when adjusting Sharpness on my RPTV ghosting appears beside or horizontal to the test pattern lines when the control is set too high. However, when adjusting the Sharpness control on my CLD-99 (using the same pattern from Video Essentials) excessive levels introduce ringing above or vertical to the test pattern lines. Obviously both settings are at the point just below the introduction of high frequency peaking. How is the CLD-99's Sharpness setting acting differently? I ended up with it set at +3.
--Jay
"No one can hear when you're screaming in digital."
My Home Theatre Pictures...
"You're no mesiah. You're, you're a movie of the week. You're a ... t-shirt, at best."
--Jay
