Car repair message board? Cherokee dash...
Discussion in 'Archived Threads 2001-2004' started by Timon Russo, Oct 31, 2001.
  1. Timon Russo
    Timon Russo Stunt Coordinator
    May 10, 2000
    213
    Where would I go for help with this problem I am having? I have a stereo I want to install in my 1995 Jeep Cherokee, but can't get the dash off to gain access to the old stereo. I get the screws out and pop it off, but can't twist it enough around the steering column to get it off or at least out of the way enough to remove the old stereo. I really want to do this myself to save a few bucks. Any advice? Or on-line resource? Thanks
  2. Andrew W
    Andrew W Supporting Actor
    Jun 19, 2001
    531
    Get the service manual. It will have the removal procedure and show you what you are missing. They're a bit expensive, but having a service manual also greatly reduces the ability of mechanics to BS you about a repair. You can look at the book and determine if they are being straight with you.
    Andrew in Austin
  3. John Johnson
    John Johnson Agent
    Sep 12, 2001
    39
    If you want to save a few bucks you can check out a Chilton's manual (probably $20-25). Go to a car parts store and you should be able to look through before/if you buy it and make sure it has the info you need...
  4. Robert McDonald
    Robert McDonald Stunt Coordinator
    Sep 23, 1999
    134
    You may want to try one of the forums at Edmunds.com
  5. Lisel
    Lisel Stunt Coordinator
    Nov 7, 1997
    53
