Ryan P
- Aug 20, 2003
I have had this particular driver for a long time and I love it. It's very similar to the stryke power 15 except it has a paper cone and dual 2ohm coils. I bought it directly from tc sounds. I recently built a new box:
2 1400 gram pr's, 145 liters, full power from mackie 1400i. So here's the deal, I can't get this thing to really rock. WHen the mackie clips it's moving about half its xmax. I have had this sub moving a solid 2 inches before, so there is no question whether or not it can do it. But I can't believe the 1200 or so watts isnt enough! (By the way it was moving 2" in a 100l box with one pr 'slapping away' and my 1000 watt car amp at 20hz and under, below 10 hz it will do over 3 inches!) I had mackie test the amp and they say its fine, but I still feel its weak, even though it passes. It might be my living room too, it has a very high slanted ceiling. I havent painted the box because Im not satisfied yet. Can you guys think of anything? I'll post pics in a little bit.
Ryan
Ryan
