Well, since you posted the question five times, I can at least answer you once. No, component is not the same as vga. Yes, you can convert component to vga. Check www.copperbox.com for the Key Digital KD-CTC transcoder. It will convert component to vga.
"Experience is the one thing you can't get for nothing." - Oscar Wilde
sorry for the reposts, but the server seems wonky with the hardware forum and wasn't going through.
I guess I need to rephrase my Q - does VGA input degrade the quality of a component signal - am I compromising anything?
My dilemma is (existing TV is 32" direct with s-video):
1. Buy $850 32" direct view TV with VGA input, spend $350 on adapter.
2. Buy $3,000 40" RPTV with component input.
Any suggestions?
thanks
Yumbo - IMDVD
No VGA is a higher quality connection than component. VGA is analog video in it's purest form.
however the transcoder if not good quality might degrade the signal.
Kevin C.
thanks,
would any degradation be any worse than component quality?
I am thinking of going the 32" first, give it to my parents when I'm ready and then get the 40" RPTV, since I just got a new amp and rear center.
ps. if a TV has a VGA input, does that mean it is progressive capable?
cheers.
Yumbo - IMDVD [Edited last by Chris Caine on September 06, 2001 at 04:21 AM]
If you use a quality transcoder like the Key Digital, there shouldn't be any (appreciable) degredation in signal quality. Key makes a lot of broadcast quality components and many folks are using the transcoder I recommended with great success with projectors with much larger screen sizes where a degraded signal would be more apparent. A VGA input doesn't necessarily mean that a TV is progressive capable, but I haven't seen any with that input that were not. It should be clearly stated in the manufacturer's specs if the TV can display a progressive signal or not.
